right lever on zero turn is stiff.
escomputers
the right lever on my 2006 cub cadet z force 50 will not move. it is super stiff. i removed linkage from front of the right hydro pump and the shaft going into the front is almost frozen solid. it will rotate if you really pry on it. almost acts like it is rusted solid but no rust visible. if you get it to turn the wheels move as they should. it is just way too stiff. is there a cause or fix for this as the mower is in good shape and runs great.
