The seat switch thinks you are not there.
To move the mower or engege the blades the set switch must be closed so check it & the wiring to it.
Depending upon which MTD you have, the seat switch will be different and MTD do things a bit different to most with the seat switch wiring which makes theirs a little tricky to bypass, which is not a good idea except to test it .
