Riding Mower deck problem.
alawa
I have a MTD Yard Machine 38inch cut. I was coming down an incline and the front of the cutting deck hit the sidewalk. Now it appears the deck is too high and even when I have my blade set to stop it will still go and it is rubbing against one of the pulleys that the main belt goes around. How do I get the deck lower so that it does not rub and so the blade disengages?
Thanks for any input!
WELCOME to these Forums...
It sounds like you have bent something... You will have to get under it and look at the hanger system... something is bent or broken and out of place... post more pictures if you find a suspect part... :smile:KennyV
