Riding mower carb adjusting
bmckinzi351
Have a riding mower with a briggs 14.5 hp engine. it backfires a few seconds after i stop the engine. read that the fuel mixture could be rich.how do i set the carb to dump in less fuel?
pugaltitude
Possible that your fuel anti fire solenoid on the bottom of carb is stuck in open position.
Nothing to do with mixture.
SONOFADOCKER
Shut the throttle down to low idle before shutting down the engine .
SONOFADOCKER
Also - because ethanol is SO bad and attracts water - I have a fuel shut off in the line - shut the fuel off and drive to the barn - by the time I get the the tractors parking space the carb is out of fuel - just remember to turn the key off after the engine stalls.
reynoldston
Sure sounds like you have that timed just right :thumbsup:
drjim
you can test to see if your fuel solenoid is functioning by disconnecting it from the carb. Ground it to the engine then turn the key. The plunger should retract then slide back out when you turn the key to the off position.
bmckinzi351
I checked the solenoid. it is not functioning. will try to find a new one and reply with the results.
Note:
I noticed that the plug that plugs into the bottom of the solenoid is rounded on one side and not the other as if it should only be hooked up one way, but the solenoid itself will accept it either way. should it be hooked up one way or the other? I tried it both ways with the same results just didn't want to ruin a new one.
Romore
Reversing the connection won't hurt anything but why would you want to if the plug only goes in one way?
