SeniorCitizen
- Aug 28, 2010
- 147
- 2,335
Ah, OK. Makes sense. That sounds like that would be an unresolveable deck problem then?
That can be corrected with a heavy flat washer welded on each side of the poorly original designed hole then bored to shaft size. Grease occasionally applied on the shaft extends the life of that component considerably. Pic before repair. No after pic available.
