peter harewood
- May 20, 2022
- 1
john deere lt133 dies when try to engage pto
No worries! On that machine, if the seat switch is bad, as soon as you let off the brake pedal, the engine will cut off, even if you're in neutral. The only switch that overrides the seat switch is the parking brake switch, which allows the operator to leave the seat and keep the engine running. On older models, such as the STX38 and some rear engine models, you could just put the trans in neutral and get off the seat without having to set the parking brake. Hope this helps!I did not assume the op had been using the motion drive, just trying to engage the deck while parked.
