Tinkerer200
- Mar 14, 2015
- 4
- 913
I have some small jumpers, 18 ga. wire with little alligator clips on the ends. To check the solenoid I might remove a small section of the insulation from the positive lead to the solenoid back far enough from the terminal so it can easily be taped afterwards. Connect one end of the jumper there and the other end directly to the battery or the battery terminal on the starter solenoid which ever is handier and see if the engine stops at its' usual time. IF so, the problem is the solenoid. IF not, the problem is in the wiring or switch. Don't forget to disconnect the jumper or you will run the battery down. Also, don't forget to check that the ground from the solenoid to the engine is good.
Walt Conner.
Walt Conner.
