corvairbob
- May 23, 2013
- 136
ihave this craftsman rider the 917.273350 with the 16 hp ohv engine. it is hard to crank over. once it starts cranking it will start hot of cold but it just does not want to start to crank. i load tested the battery it is a 200cca battery and i let the test run for 30 seconds and it did not drop on to the ?? area it held steady ar 200 cca on the tester. so i started it and the tester shows it is charging even though the onboard meter fails to show that. plus i have another meter tha tyou put on the cables and it tells if it is charging or discharging it is charging. and it draws maybe 25 amps during cranking.
i did adjust the valves but they were not out of speck. i did it cold and they were at .004 on both sides. so for the time being i'm out of ideas. it could be the starter motor but it does not get hot or even to warm during cranking. about the only thing left may be the solenoid may be getting bad and will not pass the battery current. even when it is setting ther trying to crank the crank amps sets at 25 amps it sounds like it is compression locked. s it could be the cam compression release is failing so if that is the case is that some type of decompression valve that can be installed instead of taking the engine off and apart for that? thanks
