Rgflo64
Rgflo64
B&S engine #128M020943 6.5 hp. I was mowing and stopped to clean out bag. When I tried to restart it would not start. Since then I have replaced the magneto after r bench testing and it only had 6.50 ohms. Then I removed the carb and completely cleaned it, including running g a wire through the jet all three holes. The center jet only has a hole about the size of a straight pin. After doing all of this I am getting plenty of s park
But I a m not getting fuel delivery. I am stumped.
Today's Briggs magnetos cannot be tested, as we could do with the old points/condenser systems. The ohms test you did means nothing. That being said I'll bet that the float level is too low, due to a swollen seat. I would be cleaning the carb and replacing the float needle and seat. Here is the procedure I use.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
I replaced the needle and seat and removed an Inline filter I had placed in the line. I tried to start with no result. I sprayed starting fluid in the cylinder and it turned over maybe 4 or 5 revolutions and bleached out the exhaust.
I'm assuming you cleaned the carb and set the float level as I posted. Did you check to see if fuel was coming out the nozzle when you pushed the primer? If you have enough fuel in the float bowl and the engine is priming, the next thing I would check is old fuel.
The carb has been cleaned and after cleaning I put the float in water and it floated.
Sorry I punched in the wrong engine type. Again did you check the float level as I said in my procedure. This is critical to getting fuel in the cylinder.
Sorry, I guess I can't help. Your assumptions and not wanting to follow my procedure leave me no option than to back out of this thread. The float can be adjusted, if you understood my directions and how a carb works. Hope someone else can help you or you can just purchase a new carb. Good Luck.
