I would check Part Tree and Order Tree for Parts lists for both models and see if the parts numbers are the same. You could also call the ordering numbers for these places and ask them as if you were ready to order if the parts were the same. I recently ordered a replacement steering rod for my Husky and the replacement was slightly different (narrower), but they had a plastic adapter to compensate for the difference, and the little order gal was quite knowledgeable. Let me know how you make out. Gearjammer
