Replacing rings on my GXV120
Honda laser stamps their engine numbers in the side of the block. With those numbers you will be able to locate the exact part numbers you need.
jsalis57
According to IPL for the HR215SXA within you serial range. The rings were superseded to Nippon rings.
RINGS (NIPPON)
STD 13010-ZE6-013
.25 13011-ZE6-013
.50 13012-ZE6-013
.75 13013-ZE6-013
PISTONS
STD 13101-ZE6-033
.25 13102-ZE6-033
.50 13103-ZE6-033
.75 13104-ZE6-033
OIL SEALS
OIL SEAL (12X20X5) (ARAI) 91205-KF0-003
OIL SEAL (22X35X6) 91202-ZE6-003
OIL SEAL (6X11X4) (ARAI) 91231-891-003
OIL SEAL (25X38X7) 91201-ZG9-U71
O-RING (26X2.7) 91301-805-000
O-RING (22.1X2.2) 91301-ZE9-003
GASKET, OIL PAN 11381-ZG9-T00
Thank you!
Although they do, many of the walk behind mowers engines are still only reference in the mower's IPL only as you don't find them listed those engine numbers under engine only ipls especially older models.
Have yet to find one in the last ten years that doesn’t. Just have to look for them. Have seen some clones that have Honda parts, but are not Honda engines.
jsalis57
After my phone call this morning to Parts Tree, they are confirming the ring set is the 13010-ZE6-013 as the latest variation. Still not a three piece oil seal like I was hoping for. Maybe I am just imagining such a thing.
Some time back there was another person looking for parts for their honda engine on the honda pushmower, and I asked for the engine numbers and another member Honda Robert (worked for Honda) or something like that correctly me and said that to use the honda equipment model and serial number not the engine model number to look up engine parts for those items.
I have come across engines on Honda equipment that didn't show the engine model number in their system had to use the Honda equipment model number to get engine parts. Have had a couple that when the engine model number was references pulled up the diagram for the piece of equipment so sometimes it works both ways.
jsalis57
This is exactly what PartsTree had to do, they used my model number HR 214 SX to find the part.
jp1961
Hello,
No, GXV140 rings won't work on a GXV120.
Regards
Jeff
tadawson
Start here, even if they would not be the vendor of your choice to purchse: https://www.planopower.com/oem-parts select "Honda", "Lawnmower", and then (based on your info), HR-214SXA#1, and then "Piston" and check the engine serial number range for the parts against your block. Note that *every* ring set part number has been superceded (some many times!).
(For what it's worth, I looked at all three serial number ranges, and they all point to ring set 13010-ZE6-013. This is consistent with my experience with the GXV-140 - the piston/cylinder is common to all, and only options such as PTO, etc. vary . . . Oh, and that part no. is for std - they also list oversize, and often other brand alternates . . .)
jsalis57
(For what it's worth, I looked at all three serial number ranges, and they all point to ring set 13010-ZE6-013. This is consistent with mynexperiencenwith the GXV-140 - the piston/cylinder is common to all, and only options such as PTO, etc. vary . . . Oh, and thqt part no. is for std - they also list oversize, and often other brand alternates . . .)
Thanks. I have found the part number you referenced above is consistently the one for my application. Must be correct.
