OK, I followed instructions and got everything back together. Did not seem like a big deal. I had a little problem aligning the key slots but nothing serious. BUT when I turned the axle nothing would happen. Also the eccentric arm would not move to move the clutch.
I removed the axle again and the moon key was missing. I am sure it was in place when I reinstalled the axle because I had to finagle the axle a little to get the key through the slots.
I have looked all around the tiller and the key is not there. Is there any way that the key could come out after it goes through the first gear. I fished around a little with a magnet and all I got was some sludge, 3 finish nails and part of what looked like destroyed bearing cage.
This has me baffled.
