Replacement of Gas Tank on John Deere L110
jguptonjr
Anyone out there have the instructions on replacing the gas tank on JD L110? I have removed the battery, the five bolts below the battery and the two seat springs. The problem is the steering shaft and pedestal removal. Anyone with any instructions on this procedure?
Thanks for your time and help!
Jim
Briana
Welcome to LawnMowerForum!
I moved your thread to the John Deere Forum. :smile:
JoeM(GA)
see if this helps
pile81
K so lift the seat......removed the 2, 10 mill bolts in the springs....lift up on tbe fender and wedge a piece of 2x4 in between the frame on fender......lower the deck...remove the right rear wheel ( there is a key on the axle mmake sure it goes back on) disconnect the fuel line, remove the fuel cap, remove the little tank support, and just twist the tank out front side first........no need for removing the steering pedestal at all.....
STEVEO
Thanks for this info. I just ordered a new tank due to the vent on the cap being clogged and collapsed the tank!!! About how long did the tank replacement take? Thanks, Steve
pile81
It should take about 30 minutes
STEVEO
Yes it took only about 30 min and two cups of coffee. Great instructions on the tank replacement. Thanks again Steve O
