- May 28, 2014
- 938
NorthBama...spot on.Don't know why they named them courage.where's the courage if you can only do 30hrs...russ
Have seen two one was on a nice Husqvarna machine with 60 hours
It will either be a 1" or 1 & 1/8" and most likely the former.
Your only real problem will be the PTO height.
If you don't mind a bit of metal work you can get superceeded Briggs around that size for around $ 800 with a warranty .
Kohlers go about 20% more
Add another 20% for Kwaka and
Add 10% for a Vanguard
The biggest headache from changinf brands is finding a muffler to fit or modifing the existing one to fit.
These are specific to a particular mower and in many cases the only difference from one spec to another
