Replacement Engine for a B&S 195422 8 HP
zeolot22
Hello,
I have searched the internet for a few days and cannot find anywhere to replace a Briggs & Stratton 8HP 195422 Type: 1132 01 Code: 960715#A # is maybe a 1. Can anyone point me to a place to replace this engine with the same or similar?
Thanks
Contact Briggs Directly. They have a "repower guide" but if you provide them all of the same information, they can give you any models of engines currently in production that will be a suitable replacement.
Just talked with Briggs and they pointed me to outdoorpowerdirect.com. The Engine has no replacement and can only be repaired with parts.
Just thinking out loud but perhaps I need to look into the tiller manufacturer and find out what other engines are compatible.
Solved!
B&S 195422-1132 engine.
Your engine would now be replaced
With a 10 horsepower over head valve engine as we no longer make an 8 h/p. This engine
Is also an industrial/commercial engine with a 2 year consumer warranty, 1 year commercial
Use. The new model would be a 19N132-0055 and has a list price of $439.00 but consumers
That contact us receive a discount making your cost $420.00 with $11.95 shipping and any
Possible taxes due. This would be a complete engine ready to run out of the box!
I purchased the engine and it bolted on perfectly except the crank shaft was smaller so i had to pickup a new crank shaft wheel from tractor supply for around $20.00
I am back in business.
