snappin
- Apr 18, 2012
- 1
- 10
I used Snapper Hi-Vac mowers for several seasons of working for a lawn service when out of school in the summers.They were nearly indestructable.Now(decade later)I have my own place and for the last six or seven years I have bought a new (cheap) mowerevery couple of years.My last one blew up the last mowing last year.
So when I saw this on the side of the road for sale I had to stop.It looks like a late seventies or early eightys model.
http://
I started it and tested the self propel,blade engagement and let it run for about five minutes and gave the guy 150 dollars for it.I didn't like the big plastic"pac-n-sac" so I found a regular bag and chute on E-bay for 40.dollars with shipping.
http://
So I go to use it the first time.I primed it and it started on the first pull.I started mowing and after about three minutes it died.It started back easily and ran for about six or seven minutes and quit again.Then it wouldn't start back.
My question is will it be possible to find a new replacement engine that will adapt to the self propel and the odd shape of the deck(where the motor mounts).Or even better,what is causing it to die?Any info or advice would be much appreciated.:frown:
http://
http://
