replacement crankcase
Or you could just short block (494057) it for less than a hundred more (539.95 at one site) and it includes all the gaskets for the change over. Shipping weight is 36 lbs.
Thanks for your replies/discussion. It appears I need the 807511 but would still like to know the specific difference between this and the 692543.
Do you really want to go through all the that work re-using all those used internal parts when you spend a $70 and get all the new internal parts. But maybe you like spending a lot time installing used worn parts plus any that got to replace that are bad.
Short block
vs this crankcase only part.
media.nl
Short block
media.nl
I appreciate your concern for my time and the expected outcome of my efforts. However, I can get a used crankcase for about $60 and may have to spend another $100 or so for gaskets, etc. I am retired and look at this project and something to help pass the time this winter. I have also enjoyed mechanical work but have never done it as a profession. So the used parts that I put into the used crankcase should meet my objective. Thanks.
