Franken-Roper
- May 20, 2013
- 5
- 18
Does anyone know if there is an after market carb for the Briggs 400 CC 11HP Engine? Preferbly something that does not have a float bowl. I am using a Rall Roper as a trail rider and the float bowl does not like the bouncing of the trail and the motor spits and sputters as I am going up the trail in 5th gear. 1st and second gear are fine because the Roper creeps at a snail pace but 3rd, 4th, 5th gears are faster and makes the mower bounce and sputters. If there is no carb any one know of a remedey to fix this. I got a parted out 14.5 HP Brigss with electric bowl will that work on the 11 HP motor?
