Replacement battery recommendations
There are a lot of battery brands out there but not many manufacturers.
The longest lasting battery I ever had was the one that came with an L3000DT Kubota. I replaced it after 16 years but it was still starting the tractor.
I've had good luck with Deka batteries. Deka makes batteries for NAPA.
I’d recommend an Interstate SP-40 or SP-40R, depending on post position. That all I install in twin cylinder engines.
