Jsinclair
- Jun 20, 2020
- 1
- 10
Good Afternoon,
I confirmed that the ignition coil is on the correct way. I was also able to get the spark plug to jump a .25in gap.
I also gapped the valves again (to .006), and made a quick video of the valves as the motor tried to crank (with the fuel shut off). At the beginning of the video, you hear it hit the compression release hard, pause, then resume cranking.
I also noticed that the exhaust pushrod is spinning. If you look closely in the video below you'll notice it spin as the compression releases. Is this normal?
I've pretty much accepted the fact that I am going to have to tear apart this motor again.
