Captn Cliffy
- Dec 3, 2010
- 8
- 29
Sorry if this thread already exists, but I searched and couldn't find one. I have a series 3 Snapper RER where both axle boots have cracked and split. I had downloaded a copy of the Series 3 Snapper Service Manual from their website several years ago; it has directions for removing and servicing the differential and chain case, but not for axle boot replacement specifically. The Snapper manual seems to indicate that if you remove the right fender (differential) from the main case, the fender, differential housing, and axle will all pull out from the left fender (hub removed) through the chain case as one complete unit. Doesn't work for me! I did a Google search, and looked at other forums and a couple of videos, and had conflicting instructions. Anyone have some good advice?
