Appears to be maybe at least two issues.
For ONE
We already know you are probably not getting a compression release IF the electrical/mechanical cranking system is ok.
Did you SEE the compression release bump as you slowly rotated the engine after you adjusted the INTAKE valve lash?
You can review on-line how to look for such.
For ONE
