Hi everyone. I'm new here and seeking some advice from those who know much more about this stuff than I do. I am trying to learn more about repairing small engines and I am making this motor my "guinea pig.
I had neglected a snapper riding mower with this briggs and stratton motor on it by leaving it out in the weather for about 3 years. I had only used the mower for one season and it ran great when I parked it...
I tried starting it by spraying a little ether in the spark plug hole...Got nothing. Had spark, so I tested compression. It was only 35 psi. . Rain had gotten into the valve train and rusted things up pretty good.
I have a couple of questions.
1. Are these valves worth trying to save? The intake valve is very pitted. I assume this was caused from the rust? Surprisingly, the intake doesn't leak, but the exhaust valve does. The seats are in good shape, but I think they will need to be lapped.
2. The cylinder is very smooth and not scratched, but the piston rings are stuck. What is the best way to remove them? I have been soaking them for a couple of days in a gas/seafoam mixture to no avail.
Thanks in advance!
Ken
Thanks in advance!
Ken
