Hello All!
I have a 12 or 13 year old Scotts (by john deer) self propelled mower with a 3 speed rear drive gear box and a B&S Intek 6.5hp OHV motor.
The mower has always done a decent job pf cutting the lawn. My lot size is 10K sq ft with a 1388sq ft house, double car garage, shed and graveled dual wide RV parking on one side. The lawn is not huge so I dont want a riding mower. Takes me maybe 1-1.5 hours to mow everything on the slowest speed. It's all flat.
Recently I checked the oil level in the engine and it was barley registering on the stick. I added a little oil to get it between the low and high mark. Since then the mower spews blue smoke out the muffler. I drained the oil and refilled thinking I had inadvertently overfilled it but after carefully measure the oil amount and verifying it was right between the low and high mark on the stick I still get huge clouds of smoke out the pipe. The plug is very oily.
I hooked up a compression tester and gave the cord a few yanks and it went up to 90psi. From what I have been reading that seems good given the auto decompression cams in these things. Maybe I am wrong though.
Anyhow, it is probably time for a rebuild or replacement. One of the output shafts on the transmission is seized and I had to take the gears out of the wheel so it is now a one wheel drive. The cost for a replacement transmission for this is over $200 alone. Combine that with the cost of rebuilding and I am starting to think maybe its time to get a new mower.
If I got a new mower I would be looking at the $450 or less price range.
So if this were your mower would you rebuild the engine and fix tranny or just toss it and get a new mower? It doesn't seem like they sell any push mowers with a 6.5hp engine anymore. I may miss the extra power.
Thanks for the help
Mark
Thanks for the help
Mark
