Removing mower blades
fosterlinn
I am trying to remove my mower bades from my fastrack xd 60". Having absolutely no luck. Any ideas of an easy way of doing so. thanks
Try one of these and a socket.
1/2 in. Drive 25 in. Breaker Bar
but then you got to rig something up to keep the blade from turning.
]if you have a compressor, get an impact like this:
1/2 in. Heavy Duty Air Impact Wrench
and use a 20% off coupon from here:
Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, 20 percent off coupons, No Purchase Required coupons, toolbox coupons
or try an electric impact, though they are not as powerful.
Electric Impact Wrench - 1/2"
So you're installing the blades with the impact? Not too good at guessing torque? The threads will eventually suffer the consequence.
I've been using an impact to change blades for years with no ill effects on the threads. When I see it tighten down I give it another 1/4 turn and it's done. I'm on my 4th set of blades and haven't had my sd a year!
Any idea what torque is being applied?
I use an impact and put them on with torque stick. White one 120 ft pounds. I got the kit which was a little expensive but worth money. Before I got it I bought new impact and could not get wheels off my truck. With the kit I never had another problem.
