While fueling my Husqvarna riding mower I inadvertently dropped a plastic cap from the gas can into the mowers fuel tank. I am afraid the cap, while too large to lodge in the fuel line, it might be sucked over the fuel line and disrupt the flow. Therefore, I would like to remove the fuel tank so I can retrieve the plastic cap I dropped in the tank
The owner's manual instructs to remove the seat which I have done. Then the manual goes on to instruct the user to remove the four bolts at the rear of the fender which retains the seat springs and the fender.At that point it infers that the whole fender housing can be removed by merely removing the gear shift handle hand grip and pulling the fender housing off.
I have tried that to no avail. it feels like the fender housing is also somehow fastened further forward from the seat.
PLEASE enlighten me on how to proceed. What else do I need to remove, if anything, to remove the fender housing so I can access the fuel tank? Are there additional fasteners that must be renoved / If so, where are they?
I downloaded the owner's manual but it is not very helpful. Is there a shop repair manual available? if so, where can I obtain one.
Any and all help would be greatly appreciated.
THANK YOU.
- Denver>
THANK YOU.
- Denver>
