Removing Classic Engine
Boggie123
Hi all. I need to remove the engine from my Hayter Hobby 41 mower. The engine is a Briggs and Stratton unit:
Model: 94502
Type: 5911-02
Code: 88072804
The flywheel (underneath, where the blade mounts) needs to be removed from the crank to get the engine out. I suspect it is a push fit with woodruff key (or something like that) so I soaked it in penetrating oil and made a puller, but it won't budge.
I am probably doing something wrong or missing some information/knowledge. Can anybody you help me, please?
Thanks, Ian
