is there an easy way without destroying the cap so you can use it again?
R Rockyhammock Member Joined Aug 28, 2017 Threads 4 Messages 13 Apr 26, 2021 / Removing axle cap #1 is there an easy way without destroying the cap so you can use it again?
Hammermechanicman Lawn Addict Joined Jan 10, 2020 Threads 56 Messages 3,528 Apr 26, 2021 / Removing axle cap #2 If they are the soft plastic ones a hair dryer or heat gun will soften them up and they will slip off easily
R Rockyhammock Member Joined Aug 28, 2017 Threads 4 Messages 13 Apr 29, 2021 / Removing axle cap #3 I squirted a bit of some electrical lube and got them off. Back on was harder but used the hair dryer as you stated and it worked. Thanks
Hammermechanicman Lawn Addict Joined Jan 10, 2020 Threads 56 Messages 3,528 Apr 29, 2021 / Removing axle cap #4 ?
