reinstall deck
murrayman381
I have 30" murray RE model# 13ac26jd058 manufactured 2015. I had to change the drive belt, what a pain, not the deck drive belt. Anyways, got it all back together except for the deck If I put it on front pin can't line up back two and if I get back two on can't line up front pin. It came off just fine and I didn't change anything. Is there some kinda of special way to do it? Any help would be greatly appreciated.
Tom
Due some are hung you may a board the shift the position of the deck. I even had to use two long board to raise the deck off the ground in order to get some decks reconnected.
As for tthe drove belt being a pain there are a lot worst ones out there.
murrayman381
With the help of a buddy and following instructions in manual the deck is back on. Mower is running and cutting grass again. Thank y'all for your help.
Tom
