Regulator Rectifier Purple Wire Issue
Daryl22785
Hello all,
I am having an issue with my lawn mower.
I put a new put in an new battery in and within 2 weeks the battery was dead so i looked into it a little more.
I replaced the Regulator Rectifier and looks like my purple wire was chewed and missing a bunch of wire.
My issue is i do not know where this wire should go.
Can i Splice this wire back together or run new wire?
Where does this purple wire go to?
I looked all over and could not find the other end of this wire.
I took the battery out and looked at the starter solenoid and didn't see any wires missing or hanging.
THis is a 2016 LT42
Model# 13AVA1CS056
Kohler 18HP SV541
You should be able to splice it just needs to be 14 ga. IT goes to the ignition switch and the 20 amp fuse.
