Regent Simplicty 38 inch deck
Ruffer4
Hi
I've done Spring maintenance on my Regent with a 38 inch deck with a Turbo. Wondering how may grease zerks there are. I've done the 2 spindles under the deck and both front wheels. Are there any more that i'm not aware of?
Thank you in advance
mechanic mark
Post tour 7 digit model number, example 2690814. Check front axle at backside & underneath & check between drive belt idler pulleys just below your right foot when sitting on tractor.
