I have a Redmax EBZ8001 that is great! Had this for over 10 years, had the piston replaced about 6 years ago since I was previously using regular gas, now use premium! Overall it runs very well but recently started having an issue which is carb related. I make sure I mix the gas as the manual says 2.6 ozs oil to gallon of gas.
It started not running at full speed, but after 10-12 minutes would run fine (full speed). In the last week it stopped getting to full speed at all. I noticed that when I took off the air intake, there was a puddle of gas at the bottom of the adapter just below the choke. I had purchased a new carb, so figured the fastest, easiest thing to do was swap the new one onto it. It runs but was stumbling most of the time, when I let off the throttle, wait a few seconds it gets to full speed but for only 20-30 seconds. I took the air intake off and had a puddle of gas, not as bad as the original carb, so it is still flooding out.
Since this is brand new carb, I would expect that the carb is not the culprit. Heard something about the gas cap causing this type of issue?
