MowerMike
- Sep 5, 2012
- 85
- 964
BlazNT -
I checked the extension cord that I use. It is 100' and 300 v. I've been using it with a 7.5amp blower, and a 300 v. 10' extension cord.
Is this a proper rating for the Greenworks trimmer? It is rated at 10 amps. What other numbers/characters should I be looking for on the extension cord?
Thank you.
Power cords are rated based on amps, not volts. You need at least a 14 gage medium duty 100' cord to handle a 10 amp motor. Look for 14AWG stamped on the cord. The longer the cord, the larger the wire gage that you will need.
