Matergrower
- Jun 1, 2016
- 1
- 5
I have a Weedeater brand rear tine rototiller. It has a 5 hp Briggs and Stratton horizontal engine. The problem is that the recoil starter will kick back and literally jerk the pull cord handle out of your hand. This is not an occasional thing, it happens every time the pull cord is pulled. If I'm not real quick and let the handle go it is very painful. I think I may have torn some ligaments this morning when I was not quite fast enough. This tiller is older, about 15 years, old and has had this problem since it was new. I have had other power equipment with Briggs engines both smaller and larger with recoil starters but I've never had an issue with the others. It seems that the timing is a bit off but I have no idea how to remedy this problem short of trashing this tiller and buying another.
Any suggestions are welcome. Thanks
