Recoil starter doesn't work
rednax
The rope starter on my 2 hp Tecumseh 2 cycle isn't pulled in by the spring. I took it apart and I can't get the spring to catch on the pulley. Is there any way to fix this?
If you post the model and spec numbers we should be able to find a solution for you.
