Rear engine snapper won't turn over
Remmy039
We had it running the other day and when I put everything back together it won't turn over. I checked voltage to the regulator and 12 vdc is going out of the regulator when I turn the key on. Checked all wiring could not see anything loose. What is next step, check voltage to starter?
