RE: Toro / Ogura Electric Clutch
A couple of years ago, I bought a used Toro ProLine mower (walk behind, hydro, 52" floating deck, Kohler 15hp, pull start). It had less than 300 hrs on the meter & was in good condition. The only mowing I do with it is our church property...about 5 acres. Toward the end of the first season, the blades failed to engage with the PTO switch. At that point I got the service manual from Toro & began to learn about the system. The 7.5 amp fuse was blown. Replacements blew immediately. I check the PTO switch as outlined in the service manual. I originally thought the delay module might be the problem due to a slight discoloration on one part of the sealed unit. I found an exact replacement on eBay, but got the same blown fuse. All of this led me to the clutch. The service manual stated a resistance check across the clutch terminals should be between 2.8 & 3.2 ohms, and that a reading outside those parameters indicates a field failure requiring unit replacement. Mine showed 1.8 --> so, I bought a new Ogura clutch from JThomas.com, made the swap (air gap set & burnishing procedure included), & life was good.
Until about 2 weeks ago.
While mowing at the church, the blades disengaged. No biggie. I thought maybe I had let off of the bail switch slightly. Re-engaged & kept going. Then it began to happen several times in a row (which I think had also happened the previous year). Then...nothing.
So, I quit. Checked the fuse, and...yes, it was blown. Did the resistance check across the clutch terminals...oh, no...1.8 ohms.
I have ordered another clutch & am ready to install, but at $200+ each I just want to make sure I'm covering all my bases.
My questions:
(1) How long should a clutch last? (My mower only has about 370 hrs on it how, and it's only been 1 year since replacement.)
(2) Is there something I'm doing/not doing to cause the clutch to fail?
(3) Is there some other part of the system that could be causing the unit to fail?
Thanks in advance for any input/advice.
My questions:
