Re: Problem with Grass Clippings Clogging Up the Drivetrain
ronusa
:frown::frown:Using a Honda HRR216VX rear wheel drive mower and the problem that I am having is that a large amount of grass clippings keep collecting inside the compartment on the underside of the mower deck that houses the belt and drivetrain. I have the mulch plug properly inserted; but after each use of the mower I have to turn the mower on it’s side and reach up inside this compartment and remove a good amount of grass clippings that have been collected. It is a real pain in the butt having to do this chore after every use of the mower. Otherwise if I do not do this chore then the grass clippings finally get themselves so tightly packed that it greatly affects the performance of the drivetrain. Any help or suggestions to alleviate this problem would be appreciated.
How low is your height adjustment for the ground to bed clearance?
