I've got a 2008 JD X720 w/ a 62" deck. This year I decided to do my own maintenance on the deck to learn how to take it off and re-install it so I can change blades or sharpen them on my own. I got the deck off easily but getting it back on is a different story. I did learn that by removing the lt rear wheel/tire, its much easier to get the drive shaft reconnected. The primary problem I'm having is that I can't get the rear forked lift brackets to drop. For some reason, the hydralics (which worked to raise them) won't lower them. Any ideas?
EdMac
EdMac
