UPDATE :
"" Hello Jeff. I checked your mower out today. I raised the wot RPM a bit. The speed checked out at 7 .6 mph. The engine seemed to be running fine when I was using it. ""
I am thinking it was also the new fuel I put in it helped it a bit as well, so all is good now
Now to treat the underside of the deck then I can mow in a few days YIPPY !!
Iowa weather might be good by then.
