bucsfan714
- Apr 11, 2014
- 1
- 16
What spindles are on the RSD?
Aluminum w/ 1.0" shafts and sealed ball bearings with triple protection seals.
I recently bought the Raptor SD and I'm very satisfied with the look of my 3 acres. I thought as rough as my property is that there would be more scalping but it really did a nice job. The only complaint I have is the deck spring broke at only 5 hours. Dealership replaced it with no problem but I apparently did not have the deck belt on properly. I'm guessing maybe a twist and the belt broke 2 hours later. I'm going back to dealership this morning to get a new one. I'm not sure the actual size of this belt as I haven't found a cross reference size to the part #604817. I hope this is not a re-occurring problem with this deck.
Another thing I should note is a comment from my neighbor who has been mowing his 3 acres with a Club Cadet ZTR. He could not tell a difference between the sound when the mower was engaged or disengaged. Smooth running.
I picked up the Raptor SD 54' on Saturday. Used it for the first time several evenings ago and loved it. Did have a few small bolts that needed to be retighted after mowing, but overall, performance was great. Wasn't sure between the Raptor and the SD, but decided on the SD due to the height, comfort of the seat, foot lever to raise the deck and the additional horsepower. Also in the deciding factor was the serviceable transmission.
Overall, after one time mowing, I am happy. I'll update with any new developments going foward.
Mind telling us what bolts to check? I checked over most I think, didn't find anything. Thanks
You can get a toro Titan. Has better warranties better hydro drive systems zt3100. I think 22 inch tires. Completely welded deck. I think the Titan zx 48 you can get under 5000. I'm going to be buying the titan MX 54 inch because I will get it for 5500 and cause they stopped making this model in a 48 inch cut.
