Raptor SD electric clutch replacment procedure
Sjones582
how do I remove the clutch?
Gent
Mine had Blue lock tight on the threads. It took an impact wrench to get the bolt out. it felt like the threads were stripped.
And then reinstalling require holding crankshaft still until you torque to 55 ft-lbs. Don't to make sure the antirotation bracket is place or you can destroy thee clutch. On the Double D spacer (if present) depending if it is recessed or not, it might require A Double D tool (there is at least four different sizes of D's so I got two tools at my disposal) or at least that is what I use to hold these Double D's otherwise it is a large flat blade screw driver in the flywheel ring gear while trying reach around the frame to torque the retaining screw..
