raptor SD blower bagger
chinookdriver
I've got about three to four position left and I will be as high as the deck will go. There is a company in Minnesota called protero, that might make a blower that I can install to help me out. I will sure make a post if they do.
chinookdriver
Has anyone had any experience with the Humboldt manufacturing bagger? My Hustler dealer suggested them or to up grade to the fastrak.
MrBungle
https://grasscatchersusa.com/mymower/hustler_raptor_super-duty.php
I would be interested in hearing if anyone has used Humboldt's (or any other third party) solution as well. I have a Raptor SD 54 inch and the OEM catcher system is very frustrating to use. Even in dry conditions with short grass, the grass frequently accumulates in the in the tubing and in the mowing deck which has to be manually unclogged. Additionally, the rubber bungee's that connect the tubing to the frame often break.
