Ransomes SuperCertes Cylinder to cutting blade adjusters
BEEDEEUK
  • / Ransomes SuperCertes Cylinder to cutting blade adjusters
HI, I have a Ransomes superCertes 61 on which one of the cylinder to cutting blade adjusters have seized i.e. the adjust screw and locking nut. I can loosen them until they are floating loose but I can't get them out of the cylinder bearing housing. On the parts diagram it looks like the is a M10 nyloc nut at the bottom of bearing housing. Any suggestions?
