When I take the sparking plug out and hold it against the engine while trying to start there’s no spark.(new sparking plug and "on/off" button deconnected)
However-sometimes- after many attempts starting, it starts and runs fine. Once I stop the engine it’s very difficult/impossible to start it again.
So I opened the ignition-part whitch seemed dirty and rusted. I cleaned everything but still the same result.
With a multimeter I measured primary 0.13ohm and secundary 9.73kohms (multimeter on 20k)
Is it possible to test the ignition coil?
The gap between the flywheel and te coil can not be adjusted because the coil is located inside the flywheel.
Is it possible that a bad ignition coil works sometimes and sometimes it doesn’t.
One year ago there was no problem starting but slowly it got worse.
Thank you for your reply.
