Rally / Roper
KWIKCUTUK60
Hi i live in the uk and have a Rally / Roper sit on mower Model no :- K9224BT i am trying to find out where the spring on the Brake return connects to someone said it may go to a hole in the chassis if so where ???? Also the length of the spring would be very helpfull , The spring in question is Number 19
http://partsandservice.com/db/pl/AYP/rer80at.04.gif
Looks like number 17 and 18 are the close in size. Use #17 as a guide. I would put it together then measure the distance to the hole ninus 1/2". Mounting point looks like the back or the chassis. it will be a slot then a hole. Slot on bottom and hole on top.
