My Craftsman GT5000 deck is at maximum cutting height and my Truegreen rep said to cut grass at higher level. Several people have checked the tractor/mower and said there is no more adjustments to make. Has anyone solved this problem?
Try that on lawn tractor tires ( both front and rear ) and report back the circumference differential.Easy way. Just add 5psi to each tire. Will give you about half inch
OH NO , I never say anyone is wrong. They are just required to prove to me they are right. :laughing: So go ahead and give me the circumference numbers from the 5 lb. increase and I'll calculate the diameter difference .I have tried it on many lawn tractors.
Are you trying to say I am wrong ?
First step to level a deck is make sure all the tires have the psi they should.
I guess we can skip this step from now on.
Now that we have been told that the psi in a tire does not affect the ride height.
