R1000 Craftsman 30 Inch 13.5 hp riding mower
loyolarambler
When i push the brake/clutch pedal down, the mower will not go in forward or reverse, earlier this summer, I replaced the drive belt, worked well for a couple months, what should I be looking at, there seems to be alot of play in the clutch rod Help! Please
When you push the pedal down is disengages the clutch and a bit further apples the brake so it should not move in either direction.
So want to sit down and try thinking about what you want to ask again ?
