Mr Hogg Willetts
- Oct 6, 2025
- 1
- 6
Hi, I have quick change oil valve on my Troy bilt Pony 2020.
I changed the oil yesterday. I drained it after mowing on a hot mower. the lawnmower shop owner had given me the wrong filter. It spun on but was slightly larger for a Kawasaki. I didn't realize until it was all apart.
Anyway, he had to order the right one. I re-changed the oil last night. First off, I had trouble pulling that yellow plastic valve out the second time around after turning it and getting it out of the detente. It seemed really tight to pull out. I pulled harder and it pulled out too far, making a nice mess. The little nipple on the metal part that guides through the plastic to lock it came through the factory slit. (The Part closest to the motor.
I pushed it back on and cleaned up changes the oil etc.
my question is how can I make that plastic part a little easier to pull. I cleaned it up with a toothbrush. Is the plastic part replaceable on its own? I read a Thread on here that a Said you can remove that plastic piece to tighten the actual metal valve down.
Does anyone have one of these things disassembled . I am trying to picture how this functions internally.
