Pontisteve
- Feb 8, 2012
- 5
This thread seems dead, but I couldn' resist answering. Your solution is to perform a leakdown test. With both valves closed (motor at TDC on compression stroke), air should not be able to leak out of the engine, except a small percentage past the ever-present ring leakage.
Not only will performing a leakdown test tell you the percentage of cylinder leakage you have, but the escaping air pressure will also point out where it's leaking out at. Inevitably, it's almost always out one of the two valves (due to valve or valve adjustment issues), past the rings (due to ring sealing or bore issues), past the head gasket (due to bad gasket or warped block or head), or out the piston (thru a hole in the top or side).
With a leakdown test, you can't miss.
FYI, because of the fairly low cost of small engines to be replaced with a new or used one, spending big bucks on properly machining a new bore is rarely worth it unless you do it yourself. And even if you're not great at it, as long as you have a dial bore gauge to use, you can do it good enough to make plenty of compression to get a lawn mower engine to run adequately. It's not a V8 race engine here.
